SECTIONPLANE command
Creates section entities.
Icon:
Alias: SPLANE
Creates section entities from 3D solids, 3D surfaces, polyface meshes and 3D faces. This command helps you to see inside a 3D entity.
Note: Newly created section planes have their Clip Display status set to On. As section planes are entities, they can be edited and deleted. Use the SECTIONPLANESETTINGS command to edit the section planes.
Options within the command
Note:
- Use entity snaps to make the pick points accurate.
- Turn On ORTHOMODE to create a section plane restricted to the X or Y axis.
- Dynamic dimensions are displayed if Dynamic Input (DYN) is set to On (see Dynamic dimensions article).
- Specify start point
- Specifies the starting point of a 2D section plane.
- select Face
- Select the planar face of a 3D solid.
- Draw
- Draws polygonal-shaped section planes. Define the section plane by two or more points.
- Orthographic
- Places a section plane entity in one of the six standard drawing orientations, relative to the current UCS.
