SELECTIONCYCLING system variable
Selection cycling
Controls the display options associated with overlapping objects and selection cycling.
Note: When the SELECTIONPREVIEW system variable is Off, the SELECTIONCYCLING system variable is ignored, and no badge or selection dialog box is displayed when you hover the cursor over entities.
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
-2 to 2 |
| Default value: |
2 |
| Possible options: |
-2: Selection cycling is turned off, but the setting is stored (toggled value 2) -1: Selection cycling is turned off, but the setting is stored (toggled value 1) 0: The display options are turned off 1: A badge displays when you hover over objects that overlap 2: Both a badge and the Selection dialog box displays |
Note: Use the keyboard shortcut Ctrl + W to toggle on/off the current setting of the SELECTIONCYCLING system variable.
