LOADMECHANICAL2D system variable
Mechanical 2D Editor
Controls if Mechanical 2D enablers can load.
Solo-BricsCAD
Tipo: |
Booleana |
Salvato in: |
Registro di sistema |
Valore predefinito: |
On |
Valori possibili: |
Off (0): Loading of Mechanical 2D enablers is not permitted On (1): Loading of Mechanical 2D enablers is permitted |
Note: Changing the value of this variable will take effect after restarting the application.
