DIMARC command
Creates an arc length dimension.
Icon:
Creates a dimension that measure the length of an arc or polyarc. The dimension is based on the current dimension style. Options allow you to include a leader and specify the angle and contents of the dimension text.
Method
There is one method to begin creating an arc length dimension:
- Select arc or polyline arc segment
Options within the command
- Allows you to begin creating an arc length dimension by selecting an arc or polyline arc segment.
- Location of dimension arc
- Allows you to specify a point to locate the position of the dimension arc.
- Angle
- Specifies the angle of the dimension text. A value of 0 aligns the dimension text with the dimension line. Any other value rotates the dimension text relative to the x-axis of the current UCS.
- Text
- Allows you to enter text to override the default dimension text which includes the measured length of the dimension. You can use two angle brackets <> to display the measured length of the dimension in addition to other text.
- Partial
- Allows you to specify two points for the arc length dimension.
- Leader
- Toggles On the creation of a leader from the dimension text to the arc.
- No leader
- Toggle off the creation of the leader from the dimension text to the arc.
