EXPLORER command
Opens the Drawing Explorer dialog box.
Icon:
Opens the Drawing Explorer dialog box on the last used tab or category to manage definitions and reference content that is used in the drawing.
Note: Press F1 to access help. To close, Press X.
Options within the menu bar
View
Check boxes
Toggles the visibility of specific items in the Drawing Explorer dialog box on and off.
Tree/Icons Details
Selects a visual style to list all definitions of the selected drawing.
Regen
Regenerates all definitions.
Regen at each change
Regenerates definitions each time a change has been made.
Hide xref symbols
Toggles the visibility of xref symbols on and off.
Settings
Restore Default Layout
Restores the modified layout of the Drawing Explorer to the default layout.
Options...
Displays the Drawing Explorer Options dialog box. Options regarding inserting a block can be defined.
Columns
Columns can be switched on and off and repositioned by drag-and-drop:
  • Move: drag it by its header to a new location.
  • Change width: drag the separator line back and forth.
  • Restore width: double-click the separator line.
Show all columns
Displays all columns including the ones that were hidden before.
Restore Column positions
Returns columns to their original position.
