File Types Dictionary
The file types supported in BricsCAD are:
CAD Formats Extension Description
FBX binary file FBX Mudbox format used to send 3D models to animation and rendering software; binary format creates compact files maintained by Autodesk®; see the FBXEXPORT command.
FBX ASCII file FBX Mudbox format used to send 3D models to animation and rendering software; ASCII format creates human-readable files.
AutoCAD® Drawing DWG CAD drawing format created by Autodesk®; to export drawings in an earlier version of DWG, use the SAVEAS command.
AutoCAD® ASCII DXF DXF Drawing interchange format created by Autodesk®; to create binary DXF files, use the DXFOUT command.
Drawing Template DWT Templates on which new drawings are based.
3D DWF
DWF
or
DWFx
CAD viewing format for 3D models created by Autodesk®.
Binary DWF DWF Compressed version of DWF; creates more compact files.
Zipped ASCII Encoded 2D Stream DWF v6.0 DWF ASCII version of DWF compressed into a ZIP file.
Compressed DWF v5.5 DWF Compressed ASCII version of an older version of DWF; creates more compact files.
Binary DWF v5.5 DWF Compressed version of an older version of DWF; creates more compact files.
ASCII DWF v5.5 DWF ASCII version of an older version of DWF.
IFC file IFC Saves a BIM model as an IFC file to use with an IFC-certified applications data. BIM properties are included in the IFC export.
The Industry Foundation Classes (IFC) data model is intended to describe building and construction industry.
The IFC4 Reference View file is a simplified version that allows exchanging IFC models with tools that do not support all the IFC4 features.
Revit® Project RVT
The RVT file extension is associated with Revit®, a Building Information Modeling (BIM) software developed by Autodesk®.
Unreal Engine UDATASMITH Exports BIM data to the Unreal Engine file type, which can be imported in the Twinmotion 3D architectural visualization program.
MicroStation DGN File DGN Microstation design files.
SketchUp file SKP SketchUp model files are imported as meshes. If desired, the CONVTOSOLID and CONVTOMESH commands provide easy conversion between meshes and solids.
Standards File DWS Drawing standards file, used by the STANDARDS and CHECKSTANDARDS commands.
ESRI Shapefile SHP ESRI Shape file with support for GIS data types.
Keyhole Markup Language KML, KMZ XML based format files used to define geographical data for mapping applications like Google Earth and Google Maps.
Vector Formats Extension Description
Windows Metafile* WMF Vector format created by Microsoft; used by the Clipboard; see the WMFOUT command.
Enhanced Windows Metafile* EMF Updated version of WMF.
Scalable Vector Graphics SVG Used by Web pages to display vector graphics.
Scalable Vector Graphics (SVG) is a family of specifications of an XML-based file format for describing two-dimensional vector graphics, both static and dynamic (for example, interactive or animated). The SVG specification is an open standard that has been under development by the World Wide Web Consortium (W3C) since 1999.
Lithography STL 3D format used by 3D printers.
STL (STereoLithography) is a file format native to the stereolithography CAD software created by 3D Systems. STL is widely used for rapid prototyping and computer-aided manufacturing. STL files describe only the surface geometry of a three dimensional object without any representation of color, texture or other common CAD model attributes. The STL format specifies both ASCII and binary representations. Binary files are more common, since they are more compact.
See also the STLOUT command.
Collada file DAE
3D format used by rendering and animation software.
COLLADA (from collaborative design activity) is an interchange file format for interactive 3D applications. It is managed by the nonprofit technology consortium, the Khronos Group, and has been adopted by ISO as a publicly available specification, ISO/PAS 17506.
Slide File SLD Proprietary graphics format created by Autodesk® for saving screen grabs of viewports.
3D PDF** PDF Portable Document Format (PDF) is a file format used to represent documents, independently from application software, hardware, and operating system.
HTML Format Extension Description
HTML HTM Hyper Text Markup Language format files are opened in a Web browser. The VMLOUT command exports drawings to VML (short for vector markup language) embedded in a HTML file.
Wavefront Object file OBJ A text file format which contains 3D graphic information such as vertices, normals, polygonal faces and 3D coordinates. Optionally, an OBJ file can refer to a material (MTL) file (which is also a text file) and the latter can refer to image or texture (JPG/PNG/BMP) files.
Raster Format Extension Description
Bitmap* BMP Raster format created by Microsoft; used by the Clipboard.
(*) The PICTUREEXPORTSCALE system variable sets the view size when exporting to picture formats (WMF, EMF, BMP).
(**) If the EXPORT3DPDFWRITER system variable is set to 1 - Internal 3D PDF writer, it is possible to export Mechanical Structure or exploded-view Animation.
The file types supported in Communicator for BricsCAD are:
Standard for Exchange of Product data STE, STP, STEP, STPZ STEP (Standard for the Exchange of Product Data) is an ISO standard exchange format used for representing three-dimensional data in a format that can be recognized by multiple programs.
Initial Graphics Exchange Specification IGS, IGES A file format which defines a vendor neutral data format that allows the digital exchange of information among Computer-aided design (CAD) systems.
CATIA V4 model CATIA (Computer Aided Three-dimensional Interactive Application) is a multi-platform CAD/CAM/CAE commercial software suite developed by the French company Dassault Systèmes.
CATIA V5/V6 CATPart, CATProduct, CGR V5/V6 of the Catia CAD program from Dassault.
Parasolid
XMT_TXT, XMT_BIN
X_T, X_B
Parasolid is a geometric modeling kernel originally developed by ShapeData, now owned by Siemens PLM Software (formerly UGS Corp.), that can be licensed by other companies for use in their 3D computer graphics software products.
VDA-FS VDA VDA-FS is a CAD data exchange format for the transfer of surface models from one CAD system to another. Its name is an abbreviation of Verband der Automobilindustrie - Flächenschnittstelle, which translates to the automotive industry association - surface data interface. The standard was specified by the German organization VDA.
Autodesk Inventor® IAM, IPT
Autodesk Inventor®, developed by U.S.-based software company Autodesk®, is 3D mechanical CAD design software for creating 3D digital prototypes used in the design, visualization and simulation of products.
Inventor uses specific file formats for parts (IPT) and assemblies (IAM).
Siemens JT JT is a 3D data format developed by Siemens PLM Software (formerly UGS Corp.) and is used for product visualization, collaboration, and CAD data exchange. It can contain any combination of approximate (faceted) data, boundary representation surfaces (NURBS), Product and Manufacturing Information (PMI), and Metadata (textual attributes) either exported from the native CAD system or inserted by a product data management (PDM) system.
Solid Edge PAR, PSM Solid Edge is a 3D CAD parametric feature solid modeling software, which provides solid modeling, assembly modeling and drafting functionality.
NX PRT PRT is a part or model file format used by PTC Pro/Engineer, which is a CAD program that creates design parts and assembly processes.
Creo Elements
Pro Engineer
ASM, PRT Parametric, integrated 3D CAD/CAM/CAE solution created by Parametric Technology Corporation (PTC).
SolidWorks SLDASM, SLDPRT
SolidWorks is a 3D mechanical CAD program that runs on Microsoft Windows and is being developed by Dassault Systèmes.
SLDPRT: part file, SLDASM: assembly file
The IMPORTSOLIDWORKSROTATEYZ system variable controls if geometry imported from SolidWorks files should be automatically rotated to map Y axis to Z axis.
3D PDF* PDF Portable Document Format (PDF) is a file format used to represent documents, independently from application software, hardware, and operating system.
ACIS**
ASAB, ASAT, SAB, SAT
The 3D ACIS Modeler (ACIS) is a geometric modeling kernel developed by Spatial Corporation.
XCGM XCGM Computer Graphics Metafile (CGM) File Format Family.
Note: (*) If the EXPORT3DPDFWRITER system variable is set to 0 - Communicator for BricsCAD 3D PDF writer, mechanical structure or exploded views are not supported.
Note: (**) EXPORT stores a scalefactor in the SAT and SAB files relative to mm, and IMPORT uses it to scale.
