ATTDISP command
Sets the display mode of attribute text in the drawing.
Icon:
Alias: AD
Toggles the display of attribute text in the drawing, between turn all on, turn all off, or turn on only non-visible ones.
When attributes are off or invisible, they are not displayed in the drawing and are not plotted.
Options within the command
Attribute display mode
Changes the display of attribute values:
  • display attribute (ON): displays all attributes, including those set to invisible mode by the ATTDEF command.
  • hide attributes (OF): hides all attributes.
  • display Normally: displays attributes, except those set to invisible mode.
