ATTSYNC command
Synchronizes block attributes.
![BricsCAD Lite; BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM](https://static.bricsys.com/help/images/V23/en_INTL/command-reference-lite-pro-mechanical-bim.png)
Synchronizes attribute definitions in all block references of a specified block definition.
Options within the command
- Select
- Selects the block whose attributes should be used as the template for synchronizing other blocks.
- Name
- Selects the block definition to be synchronized by name or list of names.
- ATTSYNC block?
- Synchronizes attributes in the specified blocks.
- Yes
- Synchronizes attributes in the selected block.
- No – skip block
- Does not synchronize the block and skips to next block.
