EATTEDIT command
Edits attributes contained in a single block.
Icon:
Alias: ATE
Edits the values and most properties of all attributes contained in a single block, through the Attribute Editor dialog box.
  1. Overview list
  2. Value
  3. Properties
  4. Text Options
Overview list
Displays an overview of all attributes used in the block.
Value
Displays the currently selected attribute from the list. A new value can be typed.
Properties
Specifies properties of the selected attribute.
Layer
Specifies the layer of the selected attribute.
Color
Specifies the color of the selected attribute.
Linetype
Specifies the linetype of the selected attribute.
Plot style
Specifies the plotstyle of the selected attribute.
Text Options
Text style
Specifies the font of the text in the selected attribute.
Justification
Specifies the alignment of the text in the selected attribute.
Upside down
When checked, text is displayed upside down.
Backwards
When checked, text is displayed backwards.
Height
Specifies the height of the text in the selected attribute.
Rotation
Specifies the rotation angle of the text in the selected attribute.
Width factor
Specifies the width of the text in the selected attribute.
Oblique angle
Specifies the oblique angle of the text in the selected attribute.
