FLIPLINEEDIT command
Edits parametric flip operations.
Alias: PFLIPEDIT, PARAMETRICFLIPEDIT
Method
The command lets you edit an existing flip operation.
Enter the name of the desired flip operation, then select the parametric operation data to be edited.
Note: To dynamically edit a flip operation within a parametric block, select the block and click the flip operation's grip point.
Options within the command
Selection
Lets you edit the elements selection of the specified operation.
Line
Lets you define a new flip line by selecting its start and end points.
Note: All editing options can also be accessed from the operation's right-click context menu in the Parameters Manager and Mechanical Browser panels.
