GEOGRAPHICLOCATION command
Assigns geographic location data to a drawing file.
Icon:
Alias: GEO, NORTH, NORTHDIR
Opens the Geographic Location dialog box.
In the Geographic Location dialog box, you can set the geographic location of the drawing by selecting a CRS or by manually adding the coordinates.
- GIS Coordinate System
- Advanced / BIM Settings
- Remove geographic location data
- Reports the GIS system being used by the drawing.Note: Click the Browse button (
) to change the GIS Coordinate System.
- Click to display the advanced Geographic Marker and North direction settings.
- Removes the geographic location data from the drawing.Note: The geographic location is automatically stored in the drawing and can be manually removed by using this option.
- Location of Geographic Marker / Survey Point in Real World
- Position of Geographic Marker / Survey Point in Drawing Space
- North Direction
Sets the location of the geographic marker explicitly in real world coordinates by location or manually.
Specifies the position of the geographic location point in the drawing. This can be inherited from the geographic location or manually set by entering X, Y, and Z values.
Note: You can also select a specific point in the workspace to set the position.
- North Direction
Specifies the angle of the sun from north, in the context of the world coordinate system (the angle between the True North and the Y-axis, measured clockwise).
Note: The setting is saved to the NORTHDIRECTION system variable.
About CSMAP
CSMAP is a coordinate system and map projection that makes it possible to access more geographic coordinates conversions and more precise geospatial analysis. Coordinate systems are a very important piece of mapping or geospatial coordinates, and are constantly updated.
You can download and install CSMAP coordinate system on demand following the next steps:
- Download the CSMAP coordinate system files:
- Unzip the archive and copy the contents into the BricsCAD or Bricsys installation folder:
- For versions prior to V26: paste the contents into the BricsCAD installation folder. The default path is: C:\Program Files\Bricsys\BricsCAD Vxx en_US.Important: The folder name must be CoordinateSystemFiles.
- For V26 and later: paste the contents into the Bricsys installation folder. The default path is: C:\ProgramData\Bricsys.Important: The folder name must be CoordinateSystemFiles.VersionNumber, for example, CoordinateSystemFiles.1500.
- Restart BricsCAD and run the command to display the list of coordinate systems from the Geodatabase.xml file, along with the extended coordinate systems from the downloaded archive.
