-LAYOUT command
Creates a new Layout tab via the Command line.
Creates a new Layout tab in the drawing via the Command line and sets the page and plot settings.
Options within the command
- ? to list
- Lists the names of layouts already defined in the drawing.
- Set
- Switches to the specified layout.
- New
- Creates new layouts.
- Copy
- Creates a new layout by making a copy of an existing layout.
- Delete
- Erases layouts from the drawing.
- Rename
- Renames layouts.
- SAve
- Saves the mentioned layout as DWG or DXF files format.
- Template
- Imports layouts from DWG, DWF or DXF drawing files.
Specify the file name and the layout names.
- neXt
- Displays the next layout.
- Previous
- Displays the previous layout.
