SECTIONVIEWEDIT command
Edits section views of civil entities.
Icon:
Method
Select a section view or press the Enter key.
- If you select a section view, you can choose in the Command line to edit a single or multiple section views.
- If you press Enter, the Select Section Line Group dialog box opens, to select a section line group.
Then, the Edit Section Views dialog box opens for multiple section views, while the Edit Section View dialog box opens for a single section view.
The Edit Section Views dialog box allows you to edit section views.
Section view information
Allows you to set the layer and style for the section views.
- Layer
- Sets the layer for section view by selecting it from the drop-down list.
- Style
- Sets the style for section views by selecting it from the drop-down list.
Press the three-dot button on the right to open the Select Style dialog box, where you can edit or copy a section view style.
Section line group
Displays the section line group name.
Frame settings
Opens the Frame Settings dialog box to set the width and the height of the frames. See the Frame Settings dialog box article for more information.
Section view(s)
Lists the selected section view or all section views created along the section line group.
- Select all
- Selects all section views.
Data sources
Lists the selected data sources for the current section line group.
You can deselect data sources that you want to be removed from the section views.
Also, for some data sources you can change the style.
- Manage data sources button
- Opens the Manage Data Sources dialog box.
Clip gridlines to
When ticked, it allows you to set the clip gridlines from the drop-down list.
Options within the command line
- Multiple section views
- Opens the Edit Section Views dialog box to select multiple section views in the Section views list.
- Single section view
- Accepts the selected section view and opens the Edit Section View dialog box.
- press enter key to select section line group from the list
- Opens the Select Section Line Group dialog box.
