ADDLINECURVELABELS command
Adds labels along curves or lines.
Icon:
Method
Specify the general label style names for lines and curves and select the entities (lines, polylines 3D polylines,Civil String entities) to which the labels apply. The available label style names for lines and curves are listed in the Command line.
Note: You can create or edit the label style for lines and curves by accessing the Label Style Editor dialog box from Civil Explorer panel - Settings tab.
The line and curve label has two grips. One moves the label along the segment and the other drags it away from the segment.
Note: You can edit the dragged state of the label style by accessing the Dragged state tab in Label Style Editor dialog box from Civil Explorer panel - Settings tab.
