ADDSURFACELABELS command
Creates surface labels.
Icon:
Creates spot elevation levels, slope labels or contour labels on a surface.
Method
Choose the type of the surface label and select the surface to apply to.
Options within the command
- Contour
- Creates major and minor contour labels using the available label styles.
- spot Elevation
- Creates spot elevation labels using an available label style with a specified symbol style name.
- Slope
- Creates slope labels using the available label styles.
