BACTIONBAR command
Hides or displays action bars for parameters in dynamic blocks.
Disclaimer
Important: In the event that you purchase BricsCAD in the U.S. or for use in the U.S., the feature to create or edit dynamic block definitions is neither available nor licensed to you. Please see EULA for more information.
Hides, displays or resets the position of action bars for the selected parameters in a dynamic block definition.
Note: This command is only available in the Block Editor when editing a dynamic block.
Method
Select parameters in the Block Editor, then choose whether to show, hide or reset the associated action bars.
Note:
  • All action bars are displayed at the beginning of a BEDIT session.
  • The action bars are displayed if the value of the BACTIONBARMODE system variable is 1.
Options within the command
Show
Displays the action bars for the selected parameters.
Hide
Hides the action bars for the selected parameters.
Reset
Resets the action bars to their default positions for the selected parameters.
