BASSOCIATE command
Associates an action with a parameter in a dynamic block definition.
Disclaimer
Important: In the event that you purchase BricsCAD in the U.S. or for use in the U.S., the feature to create or edit dynamic block definitions is neither available nor licensed to you. Please see EULA for more information.
Method
Select the action with no associated parameter, then select the new parameter to associate the action with.
