HELIX command
Creates a 2D spiral or a 3D helix.
                Icon:
Creates a 2D spiral or a 3D helix from a combination of options including center, radius, diameter, height, axis endpoints, turns, distance between turns, and twist.
- Center of base
- Base radius
- Start turn 2
- Start turn 3
- Top radius
- Height
Method
This command has 1 method to begin creating a helix:
- Specify center point of base
Options within the command
- Allows you to begin creating a helix by specifying the center of the base.
- Specify base radius
- Specifies the radius of the helix’s base.
- Specify top radius
- Specifies the radius of the helix’s top.
- Diameter
- Specifies the diameter of the base or top of the helix.
- Specify helix height
- Specifies the height of the helix.
- Axis endpoint
- Specifies the axis endpoint to define height and orientation of the helix in 3D space. The center of the base is used as the other axis endpoint.
- Turns
- Specifies the helix's number of turns (revolutions).Note: The number of turns cannot exceed 500.
- turn Height
- Specifies the distance between each revolution of the helix. The turn height and the number of turns define the height of the helix.
- tWist
- Specifies which direction the helix rotates.- CW: clockwise
- CCW: counterclockwise
