Insertion Cycling Order dialog box
Opens via: BCYCLEORDER command
The Insertion Cycling Order dialog box defines the cycling order of grips used as insertion points for a dynamic block definition.
Grip cycling list
Displays all available parameter grips in the current cycling order.
Move Up
Moves the parameter grip up one position in the list.
Move Down
Moves the parameter grip down one position in the list.
Cycling
Selects or deselects the Cycling check box for the selected parameters to make these available or unavailable as insertion points.
Note: You can use the Shift and Ctrl keys to create a multiple selection.
OK
Saves the changes.
Cancel
Discards the changes.
