Civil commands
The Civil commands are listed in the table below:
| Name | Title | Description |
| ADDSURFACELABELS command | Add Surface Labels | Adds spot elevation labels, slope labels or contour labels on a surface. |
| ALIGNMENT command | Alignment by PI | Creates horizontal, vertical and 3D alignments. |
| ALIGNMENT3D command | 3D Alignment | Creates a 3D alignment from horizontal and vertical alignments. |
| ALIGNMENTCURVE command | Alignment by Element - Curve | Creates an unconstrained, horizontal, curve alignment. |
| ALIGNMENTEDIT command | Edit Alignment | Edits a horizontal or vertical alignment. |
| ALIGNMENTELEMENTBETWEEN command | Alignment by Element - Between Elements | Creates a horizontal alignment constrained on both sides by other elements. |
| ALIGNMENTELEMENTFROM command | Alignment by Element - To/From Element | Creates a horizontal alignment, constrained on one side by another element. |
| ALIGNMENTLINE command | Alignment by Element - Line | Creates an unconstrained, horizontal, line alignment. |
| ALIGNMENTVERTICAL command | Vertical Alignment | Creates a vertical alignment. |
| ALIGNMENTVIEW command | Vertical Alignment View | Creates a vertical alignment view for a horizontal or 3D alignment. |
| APPLYAUTOMAPPING command | Apply Auto Mapping | Automatically applies the active auto mapping set of codes to the selected Civil points. |
| CALCULATESECTIONVOLUMES command | Calculate section volumes | Defines materials in sections and calculates section volumes. |
| CIVIL3DIMPORT command | Import Civil 3D | Imports Civil objects from a Civil 3D drawing. |
| CIVILDWGEXPORT command | Export DWG | Exports Civil objects as native DWG entities. |
| Close the Civil Explorer panel. | Closes the Civil Explorer panel to hide it from the current workspace. | |
| Open the Civil Explorer panel. | Opens the Civil Explorer panel to display it in the current workspace. | |
| CIVILPOINT command | Civil points | Creates Civil points (civil objects) represented by symbols and labels. |
| CIVILPOINTATTRIBUTES command | Civil point Attributes | Adds or removes user-defined attributes to Civil points. |
| CIVILPOINTEDIT command | Civil point Editor | Edits Civil points. |
| CIVILPOINTEXPORT command | Export Civil points | Exports Civil points to an external file. |
| CIVILPOINTGROUP command | Civil points Groups | Creates Civil point groups. |
| CORRIDOR command | Corridor | Creates a corridor from a corridor template. |
| CORRIDOREDIT command | Edit Corridor | Adds or removes a corridor region. |
| CORRIDOREXTRACT command | Extract from Corridor | Extracts 3D solids, meshes, TIN surfaces, 3D polylines or outer boundaries, from a corridor. |
| CORRIDORTEMPLATE command | Corridor Template | Creates a corridor template. |
| CORRIDORTEMPLATEELEMENT command | Corridor Template Element | Creates a corridor template element from closed polylines. |
| CORRIDORTEMPLATEELEMENTEDIT command | Edit Corridor Template Element | Adds or removes components to corridor template elements. |
| FLIPLINECURVELABELS command | Flip Label | Flips the labels components along the lines or curves. |
| GISEXPORT command | GIS Export | Exports spatial and attribute data in an ESRI SHP file. |
| GISIMPORT command | GIS Import | Imports spatial and attribute data from an ESRI SHP file. |
| GRADING command | Grading | Creates a graded surface on a TIN surface. |
| GRADINGBALANCE command | Balance Grading Volumes | Balances grading cut and fill volumes. |
| GRADINGEDIT command | Grading Edit | Splits or merges gradings. |
| IFCEXPORT command | Export to IFC | Exports the model to an IFC file. |
| LANDXMLEXPORT command | Export LandXML | Exports Civil objects to a LandXML file. |
| LANDXMLIMPORT command | Import LandXML | Creates TIN surfaces or alignments from a LandXML file. |
| LEICACONNECTOR command | Leica Connect | Creates a direct connection to a Leica Infinity file. |
| LEICACONVERT command | Leica convert | Converts or imports entities from drawings with Leica Infinity data to BricsCAD Civil objects. |
| MAPTRIM command | Boundary Trim | Trims objects to a boundary: closed polylines, circles, closed splines or ellipses. |
| MATERIALVOLUMETABLE command | Material Volume Table | Generates a material volume table. |
| MOVEBLOCKSTOELEVATION command | Move Blocks to Elevation | Updates the Z value of a block's insertion point to match the value specified in the block attribute or in the corresponding GIS data. |
| MPOLYGON command | Creates mpolygons | Creates multi-sided polygon entities by selecting closed polylines, circles or specifying points. |
| MPOLYGONEDIT command | Edits mpolygons | Adds, deletes, moves, disconnects or rebalances mpolygons. |
| POLYDISPLAY command | Changes the mpolygon display mode | Changes the mpolygon display mode for all the mpolygons in the drawing. |
| REVERSELINECURVELABELS command | Reverse Label | Reverses the direction of the line and curve label components. |
| SECTIONLINES command | Creates section lines | Creates section lines either between selected points or at user specified stations along the alignment or string. |
| SECTIONVIEWS command | Creates section views | Creates section views for Civil objects. |
| STRING command | String | Creates a Civil string object. |
| STRINGADDCURVE command | Add curves to a String | Adds curves to a Civil string. |
| STRINGADDELEVATIONPOINT command | Add elevation points for a String | Adds elevation points for a Civil string. |
| STRINGADDPI command | Add PI (Points of intersections) to a String | Adds PI to a Civil string. |
| STRINGDELETEELEVATIONPOINT command | Delete elevation points from a String | Deletes elevation points from a Civil string. |
| STRINGDELETEPI command | Delete PI from a String | Delete PI from a Civil string. |
| STRINGFROMOBJECT command | String from object | Creates a Civil string object from an existing object. |
| TIN Surface | Creates a topographical (TIN) surface. | |
| TINASSIGNIMAGE command | Assign Image to TIN Surface | Assigns a raster image to a TIN surface, as a material. |
| Edit TIN Surface | Adds or removes points, breaklines or boundaries on a TIN surface. | |
| -TINEXTRACT command | Extract from TIN Surface | Extracts meshes, solids, points, faces, contours or borders from a TIN surface. |
| TINMERGE command | Merge TIN Surfaces | Combines two or more TIN surfaces into a single TIN surface. |
| Modify TIN Surface | Deforms or smooths a TIN surface. | |
| TINPROJECT command | Project to TIN Surface | Projects points (points, blocks and text) or linear entities (lines, polylines and circles) to a TIN surface. |
| TINVOLUME command | TIN Volume Surface | Creates a TIN volume surface between a base and comparison TIN surface, or an elevation. |
| TINWATERDROP command | Water Drop | Creates a water drop path on a TIN Surface. |
