ADDSECTIONVIEWLABELS command
Adds offset elevation labels or slope labels to a section view.
Icon:
Method
Select the label type from the two options and set the label style for the section view accordingly.
Options within the command
- Offset elevation
- Allows you to set the section view offset label style name and select position.
- Slope
- Allows you to set the section view slope label style name and select position.
- Switch section
- Allows you to select another section view.
