Visibility States dialog box
Opens via: BVSTATE command
The Visibility States dialog box allows you to set the current visibility state, create new ones, and to rename or delete existing visibility states.
  1. Visibility states list
  2. Set Current
  3. New
  4. Rename
  5. Delete
Displays the available visibility states list saved in the dynamic block definition.
Set Current
Sets the selected visibility state in the list as current.
New
Opens the New Visibility State to add a new visibility state to the dynamic block definition.
Rename
Renames the selected visibility state.
Delete
Deletes the selected visibility state from the dynamic block definition.
