Civil commands
The Civil commands are listed in the table below:
Name Title Description
ADDSURFACELABELS command
Add Surface Labels
Adds spot elevation labels, slope labels or contour labels on a surface.
ALIGNMENT command
Alignment by PI
Creates horizontal, vertical and 3D alignments.
ALIGNMENT3D command
3D Alignment
Creates a 3D alignment from horizontal and vertical alignments.
ALIGNMENTCURVE command
Alignment by Element - Curve
Creates an unconstrained, horizontal, curve alignment.
ALIGNMENTEDIT command
Edit Alignment
Edits a horizontal or vertical alignment.
ALIGNMENTELEMENTBETWEEN command
Alignment by Element - Between Elements
Creates a horizontal alignment constrained on both sides by other elements.
ALIGNMENTELEMENTFROM command Alignment by Element - To/From Element
Creates a horizontal alignment, constrained on one side by another element.
ALIGNMENTLINE command
Alignment by Element - Line
Creates an unconstrained, horizontal, line alignment.
ALIGNMENTVERTICAL command
Vertical Alignment
Creates a vertical alignment.
ALIGNMENTVIEW command
Vertical Alignment View
Creates a vertical alignment view for a horizontal or 3D alignment.
CIVIL3DIMPORT command
Import Civil 3D
Imports objects from a Civil 3D drawing.
CIVILDWGEXPORT command
Export DWG
Exports civil objects as native DWG entities.
CIVILEXPLORERCLOSE command
Close the Civil Explorer panel. Closes the Civil Explorer panel to hide it from the current workspace.
CIVILEXPLOREROPEN command
Open the Civil Explorer panel. Opens the Civil Explorer panel to display it in the current workspace.
CIVILPOINT command
Civil Points
Creates civil points (civil entities) represented by symbols and labels.
CIVILPOINTATTRIBUTES command
Civil Point Attributes
Adds or removes user-defined attributes, to civil points.
CIVILPOINTEDIT command
Civil Point Editor
Edits Civil points.
CIVILPOINTEXPORT command
Export Civil Points
Exports Civil points to an external file.
CIVILPOINTGROUP command
Civil Points Groups
Creates civil point groups.
CORRIDOR command
Corridor
Creates a corridor from a corridor template.
CORRIDOREDIT command
Edit Corridor
Adds or removes a corridor region.
CORRIDOREXTRACT command
Extract from Corridor
Extracts 3D solids, meshes, TIN surfaces, 3D polylines or outer boundaries, from a corridor.
CORRIDORTEMPLATE command
Corridor Template
Creates a corridor template.
CORRIDORTEMPLATEELEMENT command
Corridor Template Element
Creates a corridor template element from closed polylines.
CORRIDORTEMPLATEELEMENTEDIT command
Edit Corridor Template Element
Adds or removes components to corridor template elements.
GISEXPORT command
GIS Export
Exports spatial and attribute data in an ESRI SHP file.
GISIMPORT command
GIS Import
Imports spatial and attribute data from an ESRI SHP file.
GRADING command
Grading
Creates a graded surface on a TIN surface.
GRADINGBALANCE command
Balance Grading Volumes
Balances grading cut and fill volumes.
GRADINGEDIT command
Grading Edit
Splits or merges gradings.
IFCEXPORT command
Export to IFC
Exports the model to an IFC file.
LANDXMLEXPORT command
Export LandXML
Exports Civil entities to a LandXML file.
LANDXMLIMPORT command
Import LandXML
Creates TIN surfaces or alignments from a LandXML file.
MAPTRIM command
Boundary Trim
Trims objects to a boundary: closed polylines, circles, closed splines or ellipses.
MOVEBLOCKSTOELEVATION command Move Blocks to Elevation Updates the Z value of a block's insertion point to match the value specified in the block attribute or in the corresponding GIS data.
MPOLYGON command Creates mpolygons Creates multi-sided polygon entities by selecting closed polylines, circles, or specifying points.
MPOLYGONEDIT command Edits mpolygons Adds, deletes, moves, disconnects, or rebalances mpolygons.
POLYDISPLAY command Changes the mpolygon display mode Changes the mpolygon display mode for all the mpolygons in the drawing.
SECTIONLINES command Creates section lines Creates section lines either between selected points or at user specified stations along the alignment or string.
SECTIONVIEWS command Creates section views Creates section views for civil entities.
STRING command String Creates a Civil String entity.
STRINGADDCURVE command Add curves to a String Adds curves to a Civil String.
STRINGADDELEVATIONPOINT command Add elevation points for a String Adds elevation points for a Civil String.
STRINGADDPI command Add PI (Points of intersections) to a String Adds PI to a Civil String.
STRINGDELETEELEVATIONPOINT command Delete elevation points from a String Deletes elevation points from a Civil String.
STRINGDELETEPI command Delete PI from a String Delete PI from a Civil String.
STRINGFROMOBJECT command String from object Creates a Civil String entity from an existing object.
TIN command
TIN Surface
Creates a topographical (TIN) surface.
TINASSIGNIMAGE command
Assign Image to TIN Surface
Assigns a raster image to a TIN surface, as a material.
TINEDIT command
Edit TIN Surface
Adds or removes points, breaklines or boundaries on a TIN surface.
-TINEXTRACT command
Extract from TIN Surface
Extracts meshes, solids, points, faces, contours or borders from a TIN surface.
TINMERGE command
Merge TIN Surfaces
Combines two or more TIN surfaces into a single TIN surface.
TINMODIFY command
Modify TIN Surface
Deforms or smooths a TIN surface.
TINPROJECT command
Project to TIN Surface
Projects points (points, blocks and text) or linear entities (lines, polylines and circles) to a TIN surface.
TINVOLUME command
TIN Volume Surface
Creates a TIN volume surface between a base and comparison TIN surface, or an elevation.
TINWATERDROP command
Water Drop
Creates a water drop path on a TIN Surface.
