-BVSHOW command
Displays selected entities for the current visibility state via the Command line.
Disclaimer
Important: In the event that you purchase BricsCAD in the U.S. or for use in the U.S., the feature to create or edit dynamic block definitions is neither available nor licensed to you. Please see EULA for more information.
Method
Select hidden entities in the dynamic block definition, then decide whether to make them visible for the current visibility state or all visibility states.
Note: Use the BVMODE system variable to control how hidden entities are displayed in the Block Editor.
Options within the command
- Current visibility
- Makes the selected entities visible for the current visibility state.
- All visibility states
- Makes the selected entities visible for all visibility states.
