BVSTATE command
Manages visibility states in a dynamic block definition.
Icon:
Disclaimer
Important: In the event that you purchase BricsCAD in the U.S. or for use in the U.S., the feature to create or edit dynamic block definitions is neither available nor licensed to you. Please see EULA for more information.
Opens the Visibility States dialog box to manage visibility states in a dynamic block definition.
Note: The command works with a Visibility parameter present in the block definition (BPARAMETER command).
The Visibility States dialog box allows you to set the current visibility state, create new ones, and to rename or delete existing visibility states.
  1. Visibility states list
  2. Set Current
  3. New
  4. Rename
  5. Delete
Displays the available visibility states list saved in the dynamic block definition.
Set Current
Sets the selected visibility state in the list as current.
New
Opens the New Visibility State to add a new visibility state to the dynamic block definition.
Rename
Renames the selected visibility state.
Delete
Deletes the selected visibility state from the dynamic block definition.
