BGRIPSET command
Edits the grips of a parameter in a dynamic block definition.
Disclaimer
Important: In the event that you purchase BricsCAD in the U.S. or for use in the U.S., the feature to create or edit dynamic block definitions is neither available nor licensed to you. Please see EULA for more information.
Method
Select the parameter to edit, then set a new number of grips for the parameter or reset the grips position.
Options within the command
- 0
- No grips are displayed in the block reference. Instead, the selected geometry can be edited in the Properties panel.
- 1
- A grip is displayed at just the endpoint of the parameter.
- 2
- A grip is displayed at both the start point and endpoint of the parameter.
- 4
- Grips will be displayed at all four points of the parameter.
Note: The number of grip options varies depending on the type of the selected parameter.
- Reposition
- Repositions the existing grips to their initial location (over the parameter key points).
