BVHIDE command
Hides selected entities for the current visibility state.
Icon:
Disclaimer
Important: In the event that you purchase BricsCAD in the U.S. or for use in the U.S., the feature to create or edit dynamic block definitions is neither available nor licensed to you. Please see EULA for more information.
Method
Select entities in the dynamic block definition, then decide whether to hide them for the current visibility state or all visibility states.
Note: Use the BVMODE system variable to control how hidden entities are displayed in the Block Editor.
Options within the command
Current visibility
Hides the selected entities for the current visibility state.
All visibility states
Hides the selected entities for all visibility states.
