-BVSTATE command
Manages visibility states in a dynamic block definition via the Command line.
Disclaimer
Important: In the event that you purchase BricsCAD in the U.S. or for use in the U.S., the feature to create or edit dynamic block definitions is neither available nor licensed to you. Please see EULA for more information.
Sets the current visibility state, create new ones, or delete existing visibility states in a dynamic block definition via the Command line.
Options within the command
New
Adds a new visibility state to the dynamic block definition.
Enter the name of the new visibility state, then enter the entity visibility for the new state.
Hide all
Hides all the entities in the block definition for the new visibility state.
Show all
Shows all the entities in the block definition for the new visibility state.
Current visibility
Adds the new visibility state with the current visibility of the entities in the block definition.
Set
Sets an existing visibility state as current.
Enter a visibility state name from the list.
Delete
Deletes the named visibility state.
Lists all visibility states saved in the dynamic block definition.
