BCONSTRUCTION command
Converts entities to construction geometry.
Icon:
Disclaimer
Creating and editing dynamic block definitions under BEDIT in Experimental mode is an experimental feature that may not yet be stable, and could be removed in the future.
Use the MANAGEEXPERIMENTALFEATURES command (or the EXPERIMENTALMODE system variable) to turn on or off experimental features, then restart BricsCAD.
The Experimental mode is turned off by default.
Important: In the event that you purchase BricsCAD in the U.S. or for use in the U.S., this feature is neither available nor licensed to you. Please see EULA for more information.
Converts selected geometric entities in a block to construction geometries during the BEDIT session.
Method
After you open a block for editing, select the geometric entities you want to convert to construction geometries.
Note:
- This command is only available during the BEDIT session.
- Construction geometries are displayed in dashed gray lines.
Options within the command
- Convert
- Converts selected geometric entities into construction geometries.
- Revert
- Reverts selected construction geometries into regular geometric entities.
- Show all
- Displays construction geometries in the current block editing session.
- Hide all
- Hides construction geometries in the current block editing session.
