Okna dialogowe About BricsCAD dialog boxAdd block to library dialog boxAdd button item dialog boxAdd Entity Alias dialog boxOkno dialogowe menedżera dodatkówAdd menu item dialog boxAdd plot style table dialog boxAdd quad button filter dialog boxOkno dialogowe Dodaj skalęAllowed deviations from center axis dialog boxAnnotation Object Scale dialog boxArc AlignedText Workshop dialog boxArray dialog boxAttach External Reference dialog boxAttach PDF underlay dialog boxAttach Point Cloud dialog boxAttach raster image dialog boxAttribute editor dialog boxAuto Match dialog boxBackground dialog boxBIM BCF panel - Custom login dialog boxBIM project info dialog boxBIM Properties dialog boxBIM Typed Plan Editor dialog boxBIM Typed Plans dialog boxBlade - BricsCAD LISP advanced development environment dialog boxBlock attribute manager dialog boxBlock Definition dialog boxBlock Replace dialog boxBlock to Xref dialog boxMechanical Properties dialog boxBoundary dialog boxBricsys license manager dialog boxCalculator dialog boxChange dictionaries dialog boxChange Icon dialog boxChange Text Case dialog boxChange URL for entity dialog boxChoose window style dialog boxClassify As Bim Element dialog boxColor based Draw Order dialog boxColumn filter dialog boxCombine Duplicate Block Definitions dialog boxOkno dialogowe Informacje o komunikatorzeCompare two models dialog boxCompositions dialog boxConfigure Settings dialog boxConfigure structure tree dialog boxConfirm deleting selected cache items dialog boxCopy To LayerCreate detail dialog boxCreate new drawing dialog boxCreate new sheet set dialog boxCreate or edit block definition dialog boxOkno dialogowe Utwórz projektCreate section/elevation dialog boxCreate sheets dialog boxCurrent Plot Style dialog boxCustomization groups dialog boxCustomize dialog boxCustomize (Tool Palettes) dialog boxOkno dialogowe Właściwości niestandardoweOkno dialogowe niestandardowe rozmiary papieruDataLink edit dialog boxOkno dialogowe menedżera łącza danychOkno dialogowe domyślna lista skalDefine Attribute dialog boxDelete duplicate entities dialog boxDigital Signatures dialog boxDrawing explorer dialog boxDrawing explorer options dialog boxDrawing properties dialog boxDrawing view presets dialog boxEdit attributes dialog boxEdit custom properties dialog boxEdit dimensioning dialog boxEdit hyperlink dialog boxEdit Propulate Template dialog boxEdit Quad Button Filter dialog boxEdit Routine dialog boxEdit scale dialog boxEdit scale list dialog boxEdit sheets dialog boxEntity grouping dialog boxeTransmit dialog boxExport DimensionStyles dialog boxExtract attributes dialog boxField dialog boxFilter Configurator dialog boxFind and replace dialog boxFlatshot dialog boxFormat dialog boxFormula column dialog boxGeographic location dialog boxGeometric tolerance dialog boxGIS Import dialog boxHatch and Gradient dialog boxOkno dialogowe Edycja kreskowaniaImport Civil 3D dialog boxImport DimensionStyles dialog boxOkno dialogowe Importuj ustawienia stronyImport Sheet Set dialog boxInsert block dialog boxInsert Block in Cell dialog boxOkno dialogowe Wstaw obiektInsert Table dialog boxInterface settings dialog boxLabel Style Editor dialog boxLayer Manager: Save, Edit and Restore Layer States dialog boxLayer Property Filter dialog boxLayer settings dialog boxLayer translator dialog boxLayout manager dialog boxLAYOUTMERGE dialog boxLayWalk dialog boxLinks dialog boxLoad application files dialog boxOkno dialogowe Wczytaj rodzaje liniiLoad Multiline Styles dialog boxLogin dialog boxOkno dialogowe Zarządzaj dostosowaniamiManage Point File Formats dialog boxManage Routines dialog boxManage Surface File Formats dialog box Map Connect dialog boxMatch Properties dialog boxMotion Path Animation dialog boxNavigate Settings dialog boxNew Layer Name dialog boxNew Multileader Style dialog boxNew Multiline Style dialog boxNew Page Setup dialog boxNew Sheet(s) dialog boxPage setup dialog boxParametric Block Assist dialog boxPaste special dialog boxPhysical materials dialog boxOkno dialogowe Znak wydrukuPlot style table editor dialog boxPlotter Configuration Editor dialog boxPoint Cloud Reference Manager dialog boxOkno dialogowe Wstępne przetwarzanie plików danych chmury punktówPrint dialog boxProfiles dialog boxProject Database dialog boxProxy information dialog boxPublish dialog boxPurge dialog boxQLeader Settings dialog boxReassociate entity data dialog boxREDIR Settings dialog boxOkno dialogowe Edycja odniesieniaRender dialog boxReplace URL text dialog boxRun BricsCAD VBA macro dialog boxSave block definition dialog boxOkno dialogowe Zapisz szczegółySave workspace dialog boxSecurity dialog boxSecurity options dialog boxSelect color dialog boxOkno dialogowe Wybierz niestandardowy blok strzałekSelect Point File dialog boxSelect Surface File dialog box Settings dialog boxSet viewpoint dialog boxSheet Properties dialog boxSheet View Properties dialog boxShow Entities with attached URLs dialog boxSpatial Locations Manager dialog boxSpell checking dialog boxStandard open file dialog boxStandard save file dialog boxSubset Properties dialog boxSymbol Style dialog boxSystem Variables dialog boxTable Cell Format dialog boxTags dialog boxTemplate column dialog boxTool image dialog boxTool Properties dialog boxUpload to Bricsys 24/7 dialog boxUser coordinate system dialog boxUser profile manager dialog boxValidate Digital Signature dialog box VBA manager dialog boxView Detail dialog boxView Options dialog boxVisual settings dialog boxWeld Symbol dialog boxWizard page dialog boxWorking sets dialog boxWrite block to file dialog boxXDATA Editor dialog boxParent topic: BricsCAD
